Unable to properly calibrate your drawings
You're unable to properly calibrate your drawings.
Cause
The document contains at least one Viewport that defines the scale and units of measurement.
Remove the unwanted viewport:
- From the
Measurements panel under Viewports, select the viewport to delete.
- Select the
Clear All Viewports icon.
- Select Clear All From Page to delete the highlighted viewport from the current page, or select Clear All From Document to remove viewports from the entire document.
If you're still unable to calibrate your drawings, there may be security settings on the document restricting access.
Measurement
What to do if you're unable to calibrate your PDF drawings.
