Error: "Word: An unknown error occurred while post-processing the PDF"
- Revu 21.1
The following message appears when you use the Microsoft Word plugin to export any Word file to a OneDrive folder:
Word: An unknown error occurred while post-processing the PDF.
Cause
We've identified an error that occurs when you attempt to use the Bluebeam plugin from Word to create a PDF directly to a OneDrive folder. We're currently working towards a fix. In the meantime, we recommend one of the following workarounds.
Solutions
Save outside of OneDrive
- In Word, save your document outside of the OneDrive folder structure.
- In the Bluebeam plugin tab, select Create PDF.
- Select your OneDrive folder.
- Select Save.
Create PDF outside of OneDrive
- Choose a folder that is outside of the OneDrive folder structure, and then select Save.
- Once the file is created, move the PDF to the appropriate OneDrive folder.
The following message appears when you use the Microsoft Word plugin to export any Word file to a OneDrive folder: Word: An unknown error occurred while post-processing the PDF. This article provides steps to troubleshoot this issue.
