Change your Studio display name
Your Studio display name is the name that appears next to your activity in Studio Projects and Studio Sessions. Both Projects and Sessions are set to the same display name by default but can be changed independently of each other. Changes to your Studio display name are reflected in the Attendees list, Markups List, and Sessions chat.
If you are instead looking to change your BBID (Studio login credentials), see Update your Bluebeam ID (BBID) account information.
Studio Projects
To change your Studio Projects display name:
  1. Go to Revu > Preferences.
  2. From the sidebar, select General, and then select Options.
  3. Next to User, enter your desired display name.
  4. Select OK.
Studio Sessions
To change your Studio Sessions display name:
  1. Go to your Studio portal page: ClosedSelect Server Region
    Studio US
    Studio CA
    Studio UK
    Studio DE
    Studio AU
    Studio SE
  2. Sign in with your BBID.
  3. Select My Profile on the left-hand side of the screen.
  4. Under the User Data tab, you'll see Default Name populated with your current display name.
  5. Select the text box, and enter your desired display name.
  6. Select Update profile.
Your new display name will now be reflected in new Projects and Sessions going forward. However, changes to your Studio display name won't be reflected in current or previous Projects and Sessions.
Preferences
Your Studio display name is the name that appears next to your activity in Projects and Sessions. Both Projects and Sessions are set to the same display name by default but can be changed independently of each other. Changes to your Studio display name are reflected in the Attendees list, Markups List, and Sessions chat (as shown below)
