Save and access Studio Projects files from your workspace
In Revu, you can open and save PDFs in a Studio Projects folder without launching Studio. This function is accessible via the Document Management Toolbar, which will still prompt you to log in with your Bluebeam ID (BBID). It's especially useful if you or your team primarily work on files in Studio.
Save a PDF with the Document Manager
  1. In Revu, open the PDF you want to save in a Studio Project.
  2. On the Document Management toolbar, select Bluebeam Studio Projects from the dropdown menu if it isn't already selected.
    If the toolbar isn't visible, go to Tools > Toolbars > Document Management.
  3. Select Save As (DMS). If prompted, log in to Bluebeam Studio.
  4. In the Save Projects File dialog, double-click the desired Projects and folder, and select OK to upload the document into the Projects.
    In Revu 21, if you have a Basics plan, the Studio Projects won't appear in the Save Projects dialog unless you were invited to it and joined via email.
Set Studio as the default open and save location
Set Studio as your default open and save location to access Studio Project files directly from your Revu workspace.
  1. Open Revu and go to Revu > Preferences.
  2. Select Studio > Options.
  3. Deselect Open and save files to Studio from toolbar only.
With this setting enabled, you can easily access Studio Project files for Sets or batch processes without having to switch to the Studio tab.
You also have the option to open files from your local disk even with Studio set as your default.
To change your default back to the local drive, go to Revu > Preferences > Studio > Options and select Open and save files to Studio from toolbar only.
