Error: "Could not connect to Studio"
When you try to create an account, log in, or upload files to Bluebeam Studio, you see this message:
"Could not connect to Bluebeam Studio."
Causes
This error can appear due to any of the following causes:
  • The firewall ports used for Bluebeam Studio connections could be blocked due to your network security policies.
  • Depending on your country or region, Bluebeam may be restricting access to Studio services due the to export laws of the United States and other jurisdictions. Learn more in the Export Controls section of our End-User License Agreement.
  • A display name isn't set for your account.
This error could also be caused by an issue with our cloud services, which will be indicated at the top of the page. You can check the Bluebeam Services Status Page for more detailed information.
Solutions
For issues with firewalls and restrictions
See Whitelist Bluebeam solutions by domains or IP addresses for the domains and ports used by Revu, Studio, and Bluebeam on web and mobile. If you're only accessing a specific region, whitelist only the necessary domains specific for that region and the required global services.
Contact your IT department to confirm that the ports are unblocked for the indicated hosts.
Revu is proxy aware and automatically uses your proxy if its configuration is recognized as valid. To force Revu to use the proxy, select Revu > Preferences, then select Studio in the sidebar. From the Options tab, select Force proxy use.
If it's necessary to input an IP address to open up the above ports (instead of the hostname, which is preferred), you may perform a nameserver lookup or ping the above hosts for their current IP addresses. Please contact your IT department for more information.
For issues with your display name
To update your account settings and provide a display name, follow these steps:
  1. Go to the Account Settings page Closedfor your region.US Region
    UK Region
    AU Region
    DE Region
    CA Region
    SE Region
  2. To the right of the Display Name field, select Edit and enter a display name.
  3. Select Save.
Error Message
Learn how to solve the error "Could not connect to Bluebeam Studio" if it appears when you try to create an account, log in, or upload files to Studio.
