Delete pages
Selected pages can be deleted from a PDF. PDF/A documents or documents that have been certified or digitally signed cannot have pages deleted.
There are a few ways to delete pages from a PDF file:
- Go to Document >
Delete Pages.
- From the Thumbnail panel, select one or more thumbnails to select a page. Hold CTRL or SHIFT to select multiple pages, then right-click on a selected page and select
Delete Pages.
Each of these methods opens the Delete Pages dialog. Choose which pages to delete from the Pages menu. Options are:
- Current: Sets the range to the current page only. The current page number will appear in parentheses, for example, Current (2) if page 2 is the current page.
- Selected: Sets the range to the current selection. This option only appears if pages were selected prior to invoking the command.
