Scripts
Scripts can be created and executed within Revu to easily manipulate PDFs and automate multi-step tasks. To learn how to create and run scripts in Revu, see Create or run scripts.
Use the Script Editor in Revu to create new scripts and edit existing ones. It is reached through the Script Manager, as demonstrated above.
Whether editing an existing script or creating a new one, the following components are available:
Name: The name of the script. Names do not need to be unique.
Icon: The icon used to identify a script in a Toolbar. Select Import to import your own icons, or use one of the standard icons available.
Commit Changes After Running Script: When enabled, the active PDF will apply the changes upon invoking the script.
It is sometimes useful to not commit changes to the currently active PDF. For example, a script could be created that applies headers/footers, adds a cover page, flattens, and then sends an email. By not setting this property, the email will have all the script's modifications, but the active PDF will not. Therefore, you can continue working uninterrupted and your email was sent with all the necessary modifications.
Script: Enter the commands to be executed with this script. Multiple script commands are supported; enter one script command per line. Each script command may include a series of required and optional parameters for controlling the function.
The Script field utilizes two features to simplify entering scripts: auto-complete and tooltips.
Auto-complete: Press Ctrl+Space or start typing in the Script field and the auto-complete feature will pull up the list of accepted script commands. The light will highlight the function that matches the text as your type. Press Enter or double-click a command to insert it into the editor.
Tooltips: Hover the mouse over a command to view tooltips, including parameters and examples. The top line contains the syntax for the function with the parameter where the cursor is located highlighted in red. The paramere will also display on a line below with a description of that parameter. The tooltip will also automatically appear after you type the opening bracket of the function, or press Ctrl+Shift+Space to bring up the tooltip relevant to the cursor's current location.
While entering script parameters, pressing the TAB key will automatically insert the default parameter.
Bluebeam scripts are a series of commands that are single word identifiers followed by a comma delimited list of parameters enclosed in parentheses. For example:
SetPDFSecurity("abacadabra", 193)
There are several different types of parameters allowed in a script:
Bool: Boolean values (true or false)
Number: Either an integer or real number (1, 3.5, 0.2, etc.)
String: Quoted list of characters ("document.pdf"). The escape character is | .
Name: Unquotes list of characters containing letters and numbers only (print, view, flatten, etc.)
Color: A special string that represents a color that is either a color name ("black" or "red") or a hex string ("#FF0000), or an integer that contains RGB values as packed bytes where B is the lower byte.
Comments may also be added by using the "%" character. Any characters following the comment character will be ignored until a new line character is encountered.
There are commands that return and accept string dictionaries containing key/value pairs of markup properties.
View the keys that are supported by those commands.
Inserts blank pages into the active document to balance the total number of pages to an odd, even, specific count, or specific page division.
Parameters
pType [String]: Specifies how blank pages will be inserted at the end of the pdf file as follows:
even = Inserts one page if needed to make count even
odd = Inserts one page if needed to make count odd
n = Inserts pages to make page count divisible by n, n is a number
-n = Inserts pages to make page count at least n pages, n is a number
pWidth [String, Optional]: Width of page in inches, last means width of last page
pHeight [String, Optional]: Height of page in inches, last means height of last page
pStyle [Number, Optional]: Page Style as follows:
0 = Blank
1 = Notebook
2 = 1/8" Grid
3 = ¼" Grid
4 = Engineering Grid
5 = 0.5 cm Grid
6 = 1 cm Grid
7 = ½" Isometric Grid
8 = 0.5 cm Isometric Grid
Example
BalancePages("even")
BalancePages(4, 8.5, 11, 1)
Converts page content colors to a color or gray scale.
Parameters
pStartColor [Color]: Start color to convert source colors to, usually darker color
pEndColor [Color]: End color to convert source colors to, usually lighter color
pScale [Bool, Optional]: Indicates that colors should be scaled from start to end
pProcessImages [Bool, Optional]: Images should be converted to new colors
pPageRange [String, Optional]: List or range of pages to be processed, -1 will process all pages, exp: 1,2,10-20
Example
ColorProcess("black", "white") % Convert to grayscale
ColorProcess("Red", "white", true, true, "10-20")
Exports the Custom Column definition of the active document to an .xml file.
Parameters
pFileName [String]: Filename to export the columns into
Example
ColumnsExport('columns.xml')
Imports a Custom Column definition .xml file into the active document overwriting any existing Custom Columns. An .xml file can be generated by either the command ColumnsExport or from within Bluebeam Revu.
Parameters
pFileName [String]: Filename of the Custom Column definition .xml file to import into the active document
Example
ColumnsImport("columns.xml")
Deletes a file from specified location.
Parameters
pFileName [String]: Filename to delete from the file system
Example
DeleteFile("c:\Directory\Filename.pdf")
Launches an Email window with the active document attached.
Parameters
pTo [String, Optional]: Email address of recipient, use ';' to delimit multiple addresses
pSubject [String, Optional]: Email subject
pBody [String, Optional]: Email body
Example
Email()
Email("support@bluebeam.com")
Embeds the sepecified JavaScript file as a document level script in the active document.
Parameters
pName [String]: Name of JavaScript Code
pFile [String]: JavaScript file to embed
Example
EmbedJavaScript("File.js")
Exports the markups in the active document to the specified output file optionally using a User ID to filter on.
Parameters
pOuputBAX [String, Optional]: Filename to export the markups into
pUserID [String, Optional]: User ID as used in bFX File Exchange to filter on when exporting markups
Example
Export("output.bax")
Export("output.bax", "12345")
Sets a file property in the active document based on the specified key and value.
Parameters
pKey [String]: Key of file property to set
pValue [String]: Desired value of file property
Example
FilePropertySet("Author", "Homer J. Simpson")
Flattens all markups on the active document to be part of the page content.
Parameters
pRecoverable [Bool, Optional]: Specifies whether or not the flatten process is reversible
pFlags [Number, Optional]: Specifies what type of markups to flatten
Default = 8191
Image = 1
Ellipse = 2
Stamp = 4
Snapshot = 8
Text and Callout = 16
Ink and Highlighter = 32
Line and Dimension = 64
Measure Area = 128
Polyline = 256
Polygon and Cloud = 512
Rectangle = 1024
Text Markups = 2048
Group = 4096
File Attachment = 8192
Flags = 16384
Notes = 32768
Form Fields = 65536
Add together all values that should be flattened
pPageRange [String, Optional]: List or range of pages to be flattened, -1 will flatten all pages, exp: 1,2,10-20
pLayerName [String, Optional]: Layer Name to flatten markups to
Example
Flatten()
Flatten(true)
Flatten(true, 9) % Flattens Images (1) and Snapshots (8)
Exports the form data in the active document to a .xml, .csv, or .fdf file.
Parameters
pFileName [String]: Filename (.xml, .csv, or .fdf) to export the form data into
Example
FormExport("formdata.fdf")
Imports an FDF file containing form data into the active document.
Parameters
pFileName [String]: Filename of FDF file to import into the active document
Example
FormImport("formdata.fdf")
Applies headers and footers to the active document.There are many codes that can be passed in as part of the header or footer text that will be dynamically substituted when the text is applied to the document.
Page Index Codes
<<1>>, <<1 of n>>, <<1/n>>, <<Page 1>>, <<Page 1 of n>>
Date Codes
<<M/d>>, <<M/d/yy>>, <<M/d/yyyy>>, <<MM/dd/yy>>, <<MM/dd/yyyy>>, <<d/M/yy>>,
<<d/M/yyyy>>, <<dd/MM/yy>>, <<dd/MM/yyyy>>, <<MM/yy>>, <<MM/yyyy>>, <<ddd MMM d, yyyy>>,
<<dddd MMMM d, yyyy>>, <<MM/dd/yyyy h:mm tt>>, <<dd/MM/yyyy HH:mm>>
Bates Numbering
<<Bates Number#Digits#Start#Prefix#Suffix>>
Examples:
<<Bates Number#6#1#_Prefix#_Suffix>>, <<Bates Number#6#1>>
File Properties
Headers and Footers also support pulling file property data from the PDF, any file property key can be
used such as:
<<Title>>, <<Author>>, <<Client>> ...
These are additional special codes:
<<FileName>>, <<Path>>, <<PageLabel>>
Parameters
pTopLeft [String]: Header text for top left of page
pTopCenter [String]: Header text for top center of page
pTopRight [String]: Header text for top right of page
pBottomLeft [String]: Footer text for bottom left of page
pBottomCenter [String]: Footer text for bottom center of page
pBottomRight [String]: Footer text for bottom right of page.
pMarginLeft [Number, Optional]: Left margin in points (72 points per inch)
pMarginTop [Number, Optional]: Top margin in points (72 points per inch)
pMarginRight [Number, Optional]: Right margin in points (72 points per inch)
pMarginBottom [Number, Optional]: Bottom margin in points (72 points per inch)
pFont [String, Optional]: Name of font to use with header and footer
pSize [Number, Optional]: Size of font
pBold [Bool, Optional]: Emboldens font
pItalic [Bool, Optional]: Italicizes font
pUnderline [Bool, Optional]: Underlines text
pColor [Color, Optional]: Color of font
pFitToContent [Bool, Optional]: Makes content of page fit inside margins
pBatesOffset [Number, Optional]: Offset of the bates numbering
pBatesKey [String, Optional]: Unique key used to persistantly store the last used Bates offset. Use this key to ensure that every bates number will be uniqiue across documents.
pPageRange [String, Optional]: List or range of pages to apply the header and footer to; -1 will apply to all pages, exp: 1,2,10-20
Example
HeaderAndFooter("", "<<dddd MMMM d, yyyy>>","<<h:mm ss tt>>","<<Author>>","","<<Page 1 of n>>", 108, 28.8, 108, 48, "Blackadder ITC", 10.0, false, false, false, "Red",false, 93, "1,3,5,10-20")
Imports the markups from list of files specified as parameters into the active document.
Parameters
pBAXorPDF [String, ...]: Filename of a bax or pdf file to import into the active document
Example
Import("markups1.bax", "markups2.bax" ...) Import("revA.pdf" ...) Import("markups1.bax", "revB.pdf" ...)
Inserts new blank pages into the active document using the specified parameters for width, height, count and style. The default count is 1 and the default style is blank.
Parameters
pIndex [Number]: Page Index in the active document to insert pages after, 0 is before first page.
pWidth [Number]: Width of page in inches
pHeight [Number]: Height of page in inches
pCount [Number, Optional]: Number of pages to insert
0 = Blank
1 = Notebook
2 = 1/8" Grid
3 = ¼" Grid
5 = 0.5 cm Grid
6 = 1 cm Grid
Example
InsertBlankPages(0, 8.5, 11) InsertBlankPages(2, 8.5, 11, 10, 3)
Inserts a PDF file into the active document using the specified parameters to control what additional data to be additionally imported such as bookmarks, file attachments, and file properties.
Parameters
pIndex [Number]: Page Index in the active document to insert pages after, 0 is before the first page
pFileName [String]: Filename of document to insert
pBookmarks [Bool, Optional]: Insert bookmarks from inserted file, default is false
pAttachments [Bool, Optional]: Insert file attachments from inserted file, default is false
pProperties [Bool, Optional]: Merge document properties from inserted file, default is false
pLayers [Bool, Optional]: Merge document layers from inserted file, default is false
pUseFileName [Bool, Optional]: User file name as Page Label, default is false
Example
InsertPages(0, "Document.pdf") InsertPages(0, "Document.pdf", true, true, true, true)
Deletes pages from the current document.
Parameters
pPageRange [String]: List or range of pages to delete. Cannot delete all pages. exp: 1,2,10-20
Example
PageDelete("1,2,10-20")
Extracts pages from the currently active pdf document.
Parameters
pPageRange [String]: List or range of pages to Extract, -1 will extract all pages, exp: 1,2,10-20
pFileNameOrDirectory [String]: Filename or directory to save the extracted pages to
pPrefix [String, Optional]: A prefix that can be appended to the filename
pSuffix [String, Optional]: A suffix that can be appended to the filename
Example
PageExtract("1-3", "c:\Directory\file.pdf")
PageExtract("1,5,10-20", "c:\Directory")
PageExtract("1,5,10-20", "filename.pdf")
PageExtract("1,5,10-20", "", "prefix_", "_suffix")
Sets the page labels for a range of pages.
Parameters
pStyle [String, Optional]: Page label style
Blank = None
D = Decimal
R = Roman numerals
A = Alphanumeric
pPrefix [String, Optional]: Prefix to prepend the label with
pStart [String, Optional]: Number to start numbering with
pPageRange [Number, Optional]: Page range to set page labels on
Example
PageLabelsSet("", "A101", "0", 1)
Rotates the active document pages by 90 degree increments.
Parameters
pRotations [Number]: Degrees to rotate pages by, must be multiple of 90
pPortrait [Bool, Optional]: Include portrait pages, default is true
pLandscape [Bool, Optional]: Include landscape pages, default is true
pPageRange [String, Optional]: List or range of pages to be Rotated, -1 will rotate all pages, exp: 1,2,10-20
Example
PageRotate(90)
PageRotate(-90, false, true, "10-20")
Prints the active document to a physical printer. There are only 3 syntaxes available for this function; see examples below. If advanced printing options are required, all 9 parameters must be specified.
Parameters
pPrinter [String, Optional]: Name of Printer
pPageSize [String, Optional]: Page size as it appears on Printer
pLandscape [Bool, Optional]: Whether to print landscape(true) or portrait(false)
pPageRange [String, Optional]: List or range of pages to be printed, -1 will print all pages, exp: 1,2,10-20
pAutoRotateAndCenter [Number, Optional]: Automatically rotated and center page content on paper.
-1 : Autorotate and center -90
0 : No autorotate and center
1 : Autorotate and center 90
pScaleType [Number, Optional]: Specifies how to scale when printing according to the following:
0 = None
1 = Fit to Paper
2 = Shrink large Images
3 = Custom
pCustomScale [Number, Optional]: If scale type is set to custom, this is the custom scale value (e.g. 0.5 would be 50%)
pDim [Bool, Optional]: Specifies whether to dim the content when printing
pCopies [Number, Optional]: Number of copies to print
Example
Print()
Print("HP Laserjet")
Print("HP Laserjet", "letter", false, "1-3", true, 1, 1, false, 1)
Prints the active document to a file. There are only 3 syntaxes available for this function, see examples below. If advanced printing options are required, all 10 parameters must be specified.
Parameters
pFileName [String]: File to print output to
0 = None
1 = Fit to Paper
3 = Custom
Example
PrintToFile("out.prn")
PrintToFile("out.prn", "HP Laserjet")
PrintToFile("out.prn", "HP Laserjet", "letter", false, "1-3", true, 1, 1, false, 1)
Takes the active document and reduces file size.
Parameters
pReduceImageLevel [String, Optional]: Specifies the compression ratio. Possible values are Low, Medium and High, the default is Low.
pImageDPI [Number, Optional]: Specifies the Image's maximum DPI, the default is 150.
pDropFonts [Bool, Optional]: Specifies if Fonts will be dropped or not, the default is true.
pDropMiscellaneous [Bool, Optional]: Specifies if Metadata, Thumbnails, Private Data, Unused Resources will be dropped or not, the default is true.
pCompressAllStreams [Bool, Optional]: Compress All Streams, the default is true.
Example
ReduceFileSize()
ReduceFileSize("High", 150, true, true, true)
Runs a repair process on the active document using the specified options.
Parameters
pFixStripedImages [Bool]: Groups neighboring image stripes into a single image
pCombineStripedImages [Bool]: Attemps to merge groups of thin adjacent images into one image
pOptimizeSolidColorImages [Bool]: Converts single color images into vector rectangles
pProcessMasks [Bool]: Fixes AutoCAD files with Blend Modes and Masks
pRemoveTextClipping [Bool]: Fixes AutoCAD files with text clipping problems
pSimplifyClippingPaths [Bool]: Fixes Revit files with text clipping problems
pRepairFontIssues [Bool]: Fixes issues with fonts
pRepairPageContent [Bool]: Removes invalid and empty page content objects - fixes issues flattening some files
Example
Repair(true, true, true, true, true, true, true, true)
Replaces pages in the current document with pages from the source document.
Parameters
pSourceFileName [String]: PDF document to get pages from
pSourcePages [String]: List or range of all source pages to use, -1 will use all pages, exp: 1,2,10-20
pPagesToReplace [String]: List or range of pages to replace, -1 will replace all pages, exp: 1,2,10-20
pContentOnly [Bool, Optional]: If true only the page content witll be replaced leaving markups and hyperlinks
Example
ReplacePages("c:\Directory\test.pdf", "1", "1")
ReplacePages("c:\Directory\test.pdf", "3,6", "4,7", true)
Reverses all pages in the document.
Parameters
None
Launches the Save As window
Parameters
pExt [String, Optional]: File extension ("pdf", "txt", "jpeg", "gif", "bmp", "png", "tiff", "docx", "doc", "rtf", "html", "xlsx", "xls", or "pptx")
Example
SaveAs("tiff")
Sets an open password on an active document.
Parameters
pOpenPassword [String]: Password to open the document
pEncryptionLevel [String, Optional]: Encryption Level to use. Values can be RC4, AES128 or AES256.
Example
SetOpenPassword("abracadabra")
Applies security permissions to the active document.
Parameters
pPermissionPassword [String]: Password to lock pdf permissions
pFlags [Number]: Specifies what permissions are allowed
Print = 1
PrintLowOnly = 2
FillForms = 4
.EditMarkups = 8
EditDocument = 16
PageManipulation = 32
CopyContent = 64
Accessibility = 128
Add together values to set permissions
pOpenPassword [String, Optional]: Password used to open the pdf file
Example
SetPDFSecurity("master", 1)
SetPDFSecurity("master", 13, "open")
Extracts all pages in page range to individual files.
Parameters
pDirectory [String]: Directory to save the extracted pages to
pUsePageLabels [Bool, Optional]: Use page labels to name extracted pages as pdf files.
pPageFormat [String, Optional]: Format to number files names for multiple pages, if pUsePageLables is true then this parameter will be ignored
Example
SplitPages("-1", "c:\Directory")
SplitPages("1,5,10", "c:\Directory", true )
SplitPages("1,5,10-20", "c:\Directory", false, " Page 001")
Places a stamp on the active document using the specified parameters.
Parameters
pFileName [String]: Filename of Stamp pOrigin [String]: Origin of where to place the stamp as follows:
"upperleft"
"upperright"
"lowerleft"
"lowerright"
"center"
"uppercenter"
"lowercenter"
pXOffset [Number]: X Offset from origin in inches
pYOffset [Number]: Y Offset from origin in inches
pRotation [Number, Optional]: Rotation in Degrees
pScale [Number, Optional]: Scale (e.g. 0.5 would be 50%)
pOpacity [Number, Optional]: Opacity (0.4 would be 40% opacity)
pBlendMode [String, Optional]: Blend Mode as follows:
"normal"
"multiply"
"screen"
"overlay"
"darken"
"lighten"
"colordodge"
"colorburn"
"hardlight"
"softlight"
"difference"
"exclusion"
"luminosity"
"hue"
"saturation"
"color"
pPageRange [String, Optional]: List or range of pages to be stamped, -1 will stamp all pages, exp: 1,2,10-20
pLocked [Bool, Optional]: Specifies whether or not the stamp should be locked
Example
Stamp("mystamp.brx", "lowerright", 0.5, 1.0, 0, 1, 1, "normal")
Exports the State Models definition of the active document to an .xml file.
Parameters
pFileName [String]: Filename to export the state models into
Example
StateModelsExport('states.xml')
Imports a State Model definition .xml file overwriting any existing State Models. An .xml file can be generated by the command StateModelsExport.
Parameters
pFileName [String]: Filename of the State Model definition .xml file to import into the active document
Example
StateModelsImport("states.xml")
Creates a thumbnail of given width and height and saves it to the specified filename. Can have an extension of most common image formats including (.bmp, .png, .jpg ...)
Parameters
pWidth [Number]: Desired width in pixels of output thumbnail image
pHeight [Number]: Desired height in pixels of output thumbnail image
pFileName [String]: Filename of desired output thumbnail image.
pPageFormat [String, Optional]: Suffix used when generatating thumbnails for multiple pages. " Page 001" would cause the resulting files to be named "File Page 001.png", "File Page 002.png" ...
pPageRange [String, Optional]: List or range of pages to have thumbnails generated for, -1 will generate thumbnails for all pages, exp: 1,2,10-20
pShowPopups [Bool, Optional]: Indicates that popups should be included
Example
thumbnail(320, 200, "thumbnail.png")
Reverses the flattening process on the active document.
Parameters
pPageRange [String, Optional]: List or range of pages to unflatten, -1 will unflatten all pages, exp: 1,2,10-20
Example
Unflatten()
Unlocks the current PDF/A-1b document for editing.
Parameters
None
Example
UnlockPDFA()
