Document menu
The Document menu provide tools for manipulating PDFs. The tools available vary slightly among Basics, Core, Complete, and Max. It is accessed by selectingDocument on the Menu bar.
Document Properties: Opens the Document Properties dialog for the active PDF, providing general property information about the document, as well as security settings.
Page Setup: Launches the Page Setup dialog to define page sizes and related behavior.
Rotate Pages: Rotates one or more pages in 90-degree increments.
Insert Menu
Blank Page: Inserts a blank page after the active page. -
Pages from Document : Inserts pages from other PDFs. -
Layered Pages: Inserts pages from other PDFs; each PDF page will become a new layer within the current PDF.
From Scanner/Camera: Opens the Scanner dialog to acquire images from a scanner or camera. Images captured result in new PDF pages.
Extract Pages: Removes or copies one or more pages from the document to a new PDF file.
Split Document: Splits the document into separate files based on either Page Count or File Size.
Replace Pages: Replaces the content of the page while keeping the markup information.
Delete Pages: Removes one or more pages from the PDF.
Crop Pages: Crops the page to remove unwanted content.
Number Pages: Changes the page labels that appear in the thumbnail view.
Create Page Labels: Opens the Create Page Labels dialog, allowing for the creation of page labels in the PDF from either bookmarks or a selected region on the page.
Headers & Footers Menu
Add: Adds a new header or footer to the document.
Edit: Edits the document's existing header or footer.
Security: Shows the current Security setting of the PDF and allows you to Change Permissions.
Compare Documents: Launches the Compare Documents dialog to highlight the differences between multiple documents.
Overlay Pages: Reveals the differences between the pages of two PDF files by creating a single layered PDF from those pages.
Stitching: Opens the Stitching panel, which allows you to combine multiple drawings into one continuous view. Available in Revu Max only.
OCR: Opens the OCR dialog, which transforms an image of text into text that can be searched and copied. Available with a Complete and Max plan only.
Script: Starts the Script Manager, which allows you automate various tasks. Available in Bluebeam Complete and Max plans only.
Translate Markups: Translates the text of markups among several languages.
Color Processing: Opens the Color Processing dialog to change colors of vector and raster image data in the PDF.
Reduce File Size: Analyzes the active PDF and determines unused elements that can be removed to reduce its file size.
Repair PDF: Processes a PDF to address specific display issues.
Archive as PDF/A: Exports a PDF that complies to the PDF/A1-b standard for archiving.
Flatten: Flattens markups in the current document, moving them from the markup stream into the main body of the PDF, rendering them uneditable.
Unflatten : Recovers markups that have previously been flattened, if Allow Markup Recovery was selected when the markups were originally flattened.
