Work with places
Places are defined and named anchors that can be linked to quickly and easily, over and over. This section covers working with places; for detailed reference please see the Links Tab section.
- Go to Window > Panels >
Links or press ALT+N to show the
Links panel. -
In the Places section of the Links panel, select
Add Place.
- Enter a name for this Place in the Name field.
Select one of the following options to describe the Location of the Place:
- Page: Use to define a page number in the PDF as the location, with option to define the scale.
- Current View: Sets the current page and scale as the location.
- Snapshot View: Use to define an area on the current page as the location. Once selected, select Get Rectangle and drag a rectangle over the desired area to set the view.
- Select OK.
Links panel. - In the Places section of the Links panel, select the name of the place to edit.
- Select
Edit Place. - In the Place dialog, change the desired settings, then select OK.
Places are arbitrary, meaning you can change the target location later without breaking links you have already made. However the Name of the Place, if changed, will break existing links. Take care to name your Place before making hyperlinks that reference those Places.
Links panel. - Hover over the desired Place name in the Places list and select the
Hyperlink icon that appears to the right of it. - Drag to define the area of the hyperlink on the PDF. Release the mouse button and the Action will be automatically defined as opening that Place.
