Edit default layer settings
The default Layer settings in Revu are changeable.
  1. Open a PDF.
  2. Go to Window > Panels > Layers or press ALT+Y to show the Layers panel.
  3. Select Add Layer from Page and select any of the menu options. The Layers dialog appears.
    If the Open dialog appears, close it.
  4. Select Edit Defaults. The Add Layer Defaults dialog appears. Change any of the available settings, as desired.
    • Appearance: Sets the default line color of the Layers. To change the default line color for a Layer, select the color box and select the desired color.
    • Default Background: Set the default background color. The default is transparent. To change the default background colorselect select the color box and select the desired color.
    • Default Blend: Determines how the color of overlapping elements are treated.
    • Default Opacity: Sets the transparency of the content in the Layer. Range is from 0% (fully transparent) to 100% (fully opaque).
    • Auto Align Limit: Filters out objects smaller than the selected limit. Larger values (such as 1/8 inch) may improve performance but don't align smaller details, while smaller values (such as 1/32 inch) may include more detail but could impact performance.
    • Advanced Color Shading: When enabled, the overlay process will employ advanced shading methods when blending colors, allowing for greater detail in the resulting drawing.
    • Include Flattened Markups: When enabled, overrides the default behavior that ignores markups that have been flattened as "recoverable".
    • Position:
      • Rotation: Sets the default rotation (in degrees) of the Layer. Range is from 0 to 360.
      • Scale: Sets the default scale of the Layer, where 1.00 is equal to 100% (so, for example, a 75% scale should be entered as .75 while a 125% scale should be entered as 1.25). Select Scale Adjustment to enable.
      • Offset X & Y: Sets the default offset position of Layer along the X and/or Y axes.
  5. Select OK.
