Center Radius measurement
The Center Radius measurement tool lets you create markups that calculate the radius of a circle by selecting the center and a point on the circumference. By default, this tool draws full circles, but you can also use it to create arcs. For a simpler way to create arcs that measure radius, see the Three-Point Radius Measurement tool.
Before you start, set the page scale for your document first. If you try to place a measurement on a page without a scale, you'll be prompted to set one.
- Go to Tools > Measure >
Center Radius.- Alternatively, select
Center Radius on the Measurements panel.
To change the units for any dimension, select the desired measurement units from the dropdowns in the Measurement Properties section of the Measurements panel. Measurements can be taken in units different from those used to set the page scale.
- Any or all of these can also be set from the Units dropdown menu on the Properties toolbar.
Changes you make to properties will apply to all new measurements until you switch tools (for example, when you place a different type of measurement). - In your document, click to set the center of the circle.
After you set the center point, choose one of the following:
- To draw a full circle, click any point on the circumference. As you move the cursor away from the center, the radius appears.
- To draw just a section of the circle (an arc), click the first point on the arc, hold the mouse button, drag along the arc, and release at the second point.
- Hold Shift while dragging to draw the arc in 45° increments..
When you've set the page scale, a preview of key measurement values appears in the lower-right corner as you place measurements to ensure precision. Hide or recall it as needed by selecting the X or the measure icon.
- Revu prevents arcs larger than 180° (a semi-circle). If you try to draw a larger arc, it flips on its axis. To create an arc larger than 180°, resize the Center Radius measurement after placing it or use the Three-Point Radius Measurement tool.
- Hold Ctrl and drag an existing markup to automatically copy it
- Change properties (Subject, Label, units, Slope, Depth) after placing the measurement by selecting it and using the Measurements panel.
Delete.
Rotate the caption: Drag the orange handle directly over the caption.
Change the length of the radius: Drag the yellow handle at the circle's center.
Move the entire markup: Drag any part except the control handles.
You can customize the appearance of a radius measurement, including line and fill color, hatch pattern, line width and style, opacity, caption font, and whether to show the caption.
To change the appearance of a Radius measurement, select the markup and select the Properties panel. Go to Window > Panels > Properties to show the Properties panel if it is hidden.
Color: Sets the line color.
Style: Determines the line pattern.
Show Caption: Display caption text. Select Edit to choose which measurements to show.
Show Centroid: Display the geometric center. If necessary, the caption will be automatically adjusted to be below the centroid.
Font Style: Control the formatting of the text. Options include Bold, Italic, Underline, and Strikethrough. Generally, any combination of these styles can be applied to format the text.
