Rectangle Sketch tool
Like the Rectangle tool, the Rectangle Sketch tool places a rectangular markup on the document; however, the length and width measurements, as well as the rotation, are input directly for exact control over the shape. Once placed, Rectangle Sketch markups behave much like Rectangle markups.
Before placing any Sketch markup on a drawing, make sure that it is calibrated to the correct scale.
Go to Tools> Sketch to Scale >
Rectangle Sketch to Scale. The mouse cursor in the main workspace changes to the Rectangle Sketch cursor and displays the measurements dialog.
- In the PDF, click where you want to place the first point. The text cursor is automatically placed in the Length field.
- Enter the length of the rectangle and press Tab on your keyboard.
- Enter the width of the rectangle and press Tab on your keyboard.
- Enter the rotation of the rectangle and press Enter on your keyboard.
Resize a segment or change its angle: Drag the appropriate yellow handle.
You can change the appearance of the Rectangle Sketch markup, including its line and fill color, hatch pattern, line width and style, and opacity.
To change the appearance of a Rectangle Sketch markup, select the markup and select the Properties panel. Go to Window > Panels > Properties to show the Properties panel if it is hidden. Several properties will also be available on the Properties toolbar when the markup is selected.
Color: Sets the line color.
Show Segment Values: Shows all measurements available for the markup. When enabled, select an alignment for the measurements, either equal to the angle of the segments or horizontally.
Show Caption: Toggles the markup to show or hide the markup caption (as seen in the Preview Window).
Show Centroid: Marks the geometric center of the markup.
