How to back up, reset, and restore Revu settings
Backing up your Revu settings
Backing up your Revu settings creates a .zip file that you can revert to in case you experience computer issues, or if you need to migrate to a new computer. Even if you’re not immediately moving to a new computer, it’s a good idea to keep a backup file in a location other than your local hard drive, so it can be restored in the event of a hard drive failure.
To back up your settings with Revu:
  1. Open Revu.
  2. Go to Revu > Preferences (Ctrl+K).
  3. From the sidebar select Admin, then select Options at the top.
  4. Select Backup.
  5. When prompted, save your .zip file to a secure location.
Your back up Revu .zip file has been saved. Repeat this process as necessary, such as when you make significant changes to your settings.
Digital IDs and stamps aren't included in backup files and will need to be exported/imported separately. To learn more about backing up your custom stamps, please see this article.
Manually backing up your settings
You can also back up the entire folder manually, or add the folder to your backup routine. It’s located in:
C:\Users\<UserName>\AppData\Roaming\Bluebeam Software\Revu
Once you’re inside the Revu folder, you’ll see a subfolder labeled 21 or 20 (named after the installed version).
Reset your Revu settings
The reset settings option in Revu resets your settings to their original configurations. Before proceeding, we recommend backing up your settings in case this reset doesn't produced the desired result.
Revu will quit and re-launch during this process. Please make sure to save any work before continuing.
To reset your settings:
  1. Open Revu.
  3. From the sidebar, select Admin, then select Options at the top.
  4. Click Reset, then select OK.
    Revu will now close and re-launch on its own.
Your Revu settings have been reset to their original configurations.
Restore your Revu settings
Restoring your settings lets you return your Revu configuration settings to a previous state by uploading a backup file.
To restore your settings:
  1. Open Revu.
  3. From the sidebar select Admin, then click Options at the top.
  4. Click Restore, then click OK.
  5. Locate your Revu settings backup file and click Open.
Revu will close, then reopen with your restored settings.
Back up advanced Revu settings
You can also back up other Revu settings, such as the Bluebeam Printer, plugin options, and email templates. If you haven't changed the following settings, backing them up is not necessary.
Custom page sizes for the Bluebeam Printer and plugins
To back up custom page settings:
  1. Open the Bluebeam Administrator. In Windows, press the Windows key and type Bluebeam Administrator.
  2. Click the Net Config tab.
  3. Double-click the path next to Printer Driver.
  4. Copy the file prtPages.xml to the same location as the rest of your backup.
Custom Page setups for the plugins
To back up custom page setups:
  3. Double-click the path next to Global Page Setup.
  4. Copy the files *.plugin.xml to the same location as the rest of your backup.
Email templates
To back up your email templates:
  1. Open the Bluebeam Administrator . In Windows, press the Windows key and enter Bluebeam Administrator <version number>.
  2. Select the Net Config tab.
  3. Double-click the path next to E-mail Templates.
  4. Copy all the files in the folder to the same location as the rest of your backup.
Preferences
Once you’ve customized Revu, you should back up your settings in case you have computer issues or need to migrate to a new computer. Read on to learn how.
