How to create black and white PDFs from AutoCAD
Revu 20 & below
AutoCAD's plot style tables (".ctb" and ".stb" files) define the line color and line weight when PDFs are created from AutoCAD drawings. Use the following instructions to create a black and white PDF.
Using the settings in the AutoCAD page setup through the Create PDF button of the plugin:
- Open the drawing in AutoCAD.
- Select the Layout tab you want to configure.
- Click File > Page Setup Manager > Modify.
- Select monochrome.ctb in the Plot style table list.
- Check the Plot with plot styles check box, and click OK.
- Click Create File to create the PDF file.
Using the Custom PDF Page Setup through the Change Settings button of the plugin:
- Click Change Settings, then the Page Setup tab.
- Select Custom or Global in the Page Setup list.
- Select monochrome.ctb in the Plot style table list, and then check the Plot with Plot Styles check box.
Using the Bluebeam PDF printer:
- Open the drawing in AutoCAD, AutoCAD LT or Design Review.
- Select the Layout tab you want to plot.
- Click File > Plot, or File > Print > Plot.
- Select Bluebeam PDF in the Printer/plotter Name list.
- Select monochrome or Grayscale in the Plot style table list.
- Check the Plot with plot styles check box, and then click OK.
Integrations & Plugins
