How to customize Revu keyboard shortcuts
In Revu, it's easy to access certain tools and features using keyboard shortcuts. If you'd like to customize your workspace, you can edit default shortcuts and even import your own custom shortcuts onto another device with Revu installed.
In this article, we'll go over how to customize your Revu keyboard shortcuts and how to share them via exporting/importing.
Edit keyboard shortcuts
- Open
Revu.
- Go to Revu > Keyboard Shortcuts.
- Choose Tools or Commands from the top of the Keyboard Shortcuts dialog box and locate the feature(s) you'd like to update the keyboard shortcuts for.
- Select a desired Function and enter your new keyboard shortcut for it in the Shortcut field. If the shortcut is already taken or assigned, a message will appear asking whether you'd like to reassign the existing key or change the input for your custom shortcut. If you input a numerical shortcut, it will alert you that it's already reserved. This is because numbers are used as hot keys for anything saved in My Tools in the
Tool Chest.
- After assigning all your new shortcuts, click OK.
At any time, you can select Restore Defaults to revert to the original keyboard shortcuts.
Import a keyboard shortcut file
If you'd like to transfer your custom keyboard shortcuts to another computer and/or share them with another Revu user, you can easily export and import them. To get started, follow the steps below:
- Open
Revu.
- From the navigation bar, go to Revu > Keyboard Shortcuts.
- In the Keyboard Shortcuts dialog box, select Export > Settings.
- Save the XML file to a local/network location you can easily access.
- Next, download the XML export to the new computer/device.
- On the new computer, open
Revu.
- Select Import and navigate to your XML export.
- Click Open.
- Select OK in the Keyboard Shortcuts dialog box to start using the imported shortcuts.
Preferences
Interface & Navigation
