How to open a browser PDF in Revu
This article applies to:
  • Revu 21
  • Revu 20
You can open an external PDF file directly in Revu by modifying your browser settings and selecting Revu as your default PDF viewer.
Set a browser PDF to open in Revu
  1. Go to your browser settings and enter PDF in the search bar to get to PDF settings.
    Animated image showing how to get to PDF settings in Google Chrome
    In the latest version of Google Chrome, select Site settings > Additional content settings > PDF documents.
  2. After navigating to PDF settings, select Download PDFs or its equivalent. In other browsers, you'll see something similar to 'Download PDF files instead of automatically opening them in the browser.'
  3. In Windows, go to Default apps under your system settings, and select Choose default apps by file type.
  4. Find .pdf under file types and select Revu as the default app.
    Chrome browser setting screen showing Revu as the selected default app for PDFs
    Select a default app for PDFs in Windows.
Next time you open a PDF file in your browser, the file will be automatically downloaded and you will see the Bluebeam file icon next to your PDF. If Revu isn't open on your computer, opening the file will launch Revu. Otherwise, the file will simply open in Revu.
Enable the Revu preview pane
After setting Revu as your default PDF viewer, you can also enable the Revu preview pane. To do this:
  1. Open the Windows File Explorer and select the View tab.
  2. In the Panes menu, select Preview Pane. Preview Pane appears highlighted in blue after selecting it.
  3. Locate a PDF using the File Explorer and select it. The Revu preview pane appears.Image that illustrates the Revu Preview Pane.
Use the Revu preview pane to quickly scroll, zoom, or rotate a selected PDF.
PDF Management
