Use the Snapshot Tool to create custom markups
This article applies to:
The Snapshot tool allows you to copy text, raster, or vector data from your PDF to the clipboard. Pasting the snapshot onto a PDF in Revu creates a new, vectorized image, allowing you to adjust properties like size and color. If you would like to save the snapshot as a markup, you can also add it to the Tool Chest for later use.
Taking a snapshot
- Go to Edit > Snapshot (G).
If you do not want to include markups in your snapshot, go to Edit > PDF Content > Snapshot Content (shift-G) to take a snapshot of only the PDF content.
- Set and drag the cursor to form a rectangle around the desired area. Additionally, you can set points to define a polygonal shape around the area. The selected area flashes blue when a snapshot has been taken.
When you're in Snapshot mode, set-and-drag the cursor to form a rectangle around the desired area. - Press ESC to exit Snapshot mode.
- Paste the snapshot to desired area by going to Edit > Paste (Ctrl + V).
- Adjust the position or orientation of the snapshot as needed.
Formatting and saving your snapshot to the Tool Chest
- To adjust the colors of your snapshot, right-click the snapshot and select Change Colors.
Adjusting the color of a snapshot works much like adjusting the colors of a PDF. See Color Processing to learn more.
- After adjusting the properties of your snapshot, save it to the Tool Chest by right-clicking the snapshot and selecting Add to Tool Chest > (desired tool set).
Customize and save your snapshot to the tool chest.
You can now use your snapshot as a markup for your documents whenever you need it.
Markup
The snapshot tool allows you to copy text, raster, or vector data from your PDF to the clipboard. Pasting the snapshot onto a PDF (within Revu) creates a new vectorized image, allowing you to adjust properties such as size and color. If you would like to keep the snapshot for use as a markup, you can also add it to the Tool Chest for later use.
