How to use viewports
Revu allows you to create viewports, which are areas with different measurement scales than the rest of the PDF. All measurement markups you add within these viewports will adhere to that viewport's specific scaling.
To create viewports:
- In the Measurements panel, select the Add Viewport button to define a viewport.
- Select OK in the pop-up window, and click and drag to define the region for the new viewport.
- Enter a label for the viewport, and select from either the preset scales or set your own custom scale.
- Select Apply.
To change the name and/or scale of a viewport, select the menu icon for the desired viewport.
To delete a viewport, select the viewport and click theDelete Viewport button. To delete all viewports from either the page or the entire document, select the Clear AllViewports button.
Measurement
