How to save and access Studio Project files from your workspace
- Revu 2019
In Revu, you can open and save PDFs in a Studio Project folder without launching Studio. This function is accessible via the Document Management Toolbar and will prompt you to login with your BBID credentials. It's especially useful if you and/or your team primarily work on files in Studio. Here's how to use it:
Save a PDF with the Document Manager
- In Revu, open the PDF you want to save.
- From the Document Management toolbar, select Bluebeam Studio Projects from the dropdown menu if it isn't already selected.If the toolbar isn't visible, go to Tools > Toolbars and select Document Management.
- Click Save As (DMS) . You'll be prompted to log into Bluebeam Studio if you haven't done so already.
- When the Save Project File dialog appears, double-click on the desired project and folder. Click OK to upload the document into the project.
Set Studio as default open/save location
If you would like to set Studio as your default open/save location to access Studio Project files directly from your Revu workspace, follow the steps below:
- Open Revu and go to Revu > Preferences (Ctrl+K).
- Select Studio > Options.
- Make sure the Open and save files to Studio from toolbar only box is unselected.
Revu will now default to Studio Project locations automatically when you open/save a PDF while signed into your BBID account.
You'll still have the option to open files from your local disk even with Studio set as your default.
To change your default back to the local drive though, go to Revu > Preferences (Ctrl+K) > Studio > Options and select the Open and save files to Studio from toolbaronly checkbox again.
