Ellipse Sketch tool
Like the Ellipse tool, the Ellipse Sketch tool places an elliptical markup on the document; however, you input the height and width measurements, as well as the rotation, directly for exact control over the shape. Once placed, Ellipse Sketch tool markups behave much like Ellipse markups.
Before placing any Sketch markup on a drawing, make sure that it is calibrated to the correct scale.
The information input to create an ellipse using the Ellipse Sketch tool depends on the Default Ellipse Mode setting selected in the Sketch Tools Preferences. The procedure below assumes the following:
The Sketch tool preference setting is Normal; when the preference is set to Radius, you can enter only the radius to create a circle.
You're creating the ellipse by entering values in the measurements dialog, rather than by dragging the cursor.
Go to Tools > Sketch to Scale >
Ellipse Sketch to Scale. The mouse cursor in the main workspace changes to the Ellipse Sketch tool cursor and displays the measurements dialog.
The Ellipse Sketch tool cursor has two modes: Circle (which has only one input for radius) and Ellipse. Press CTRL on the keyboard to switch between them. The default mode can be set in the Sketch Preferences. - In the PDF, click where you want to place the first point. The text cursor is automatically placed in the Width field.
- Enter the width of the ellipse and press the Tab key on your keyboard.
- Enter the length of the ellipse and press the Tab key on your keyboard.
- Enter the rotation of the ellipse and press the Enter key on your keyboard.
Resize a segment or change its angle: Drag the appropriate yellow handle.
You can change the appearance of the Ellipse Sketch tool markup, including its line and fill color, hatch pattern, line width and style, and opacity.
To change the appearance of an Ellipse Sketch tool markup, select the markup and select the Properties panel. Go to Window > Panels > Properties to show the Properties panel if it is hidden. Several properties will also be available on the Properties toolbar when the markup is selected.
Color: Sets the line color.
Show Segment Values: Shows all measurements available for the markup. When enabled, select an alignment for the measurements, either equal to the angle of the segments or horizontally.
Show Caption: Toggles the markup to show or hide the markup caption (as seen in the Preview Window).
Show Centroid: Marks the geometric center of the markup.
