Polyline Sketch tool
Like the Polyline Tool, the Polyline Sketch tool draws a segmented line as a markup; however, the length and rotation of the segments are input directly for exact control over the shape. Once placed, a Polyline Sketch markup behaves much like a Polyline markup.
Before placing any Sketch markup on a drawing, make sure that it is calibrated to the correct scale.
Go to Tools > Sketch to Scale >
Polyline Sketch to Scale. - In the PDF, select where you want to place the first point. The Polyline Sketch cursor displays the measurements dialog, and the text cursor is automatically placed in the Length field.
- Enter the length of this segment of the polyline and press Tab to go to the Rotation field.
- Enter the rotation of the this segment of the polyline and press Enter. The rotation can be relative to the last angle entered or to the page, as determined by the Sketch Tools Preferences.
- Repeat steps 3-4 to draw the remaining segments of the polyline.
- To complete the line, do one of the following:
- Press Enter twice.
- Press C.
- Double-click the last point placed.
Control points define where line segments meet in a multi-segment markup. Add or remove control points to adjust the shape. See Working with Control Points for more information.
Convert line segments to curves or arcs at control points to match complex shapes. See Working with Curved Markups for more information.
Resize a segment or change its angle: Drag the appropriate yellow handle.
You can change the appearance of the Polyline Sketch Tool markup, including its color, thickness, pattern, ends, and opacity.
To change the appearance of a Polyline Sketch Tool markup, select the markup and select the Properties panel. Go to Window > Panels > Properties to show the Properties panel if it is hidden. Several properties will also be available on the Properties toolbar when the markup is selected.
Color: Sets the line color.
Style: Determines the line pattern.
Start and End: Controls the appearance of the endpoints for each side of the line. The diagram below shows samples of each type of endpoint.
Each endpoint has an associated Scale that determines the size of the endpoint in relation to the Line Width. By default, it is set to Auto and will automatically adjust as the Line Width is changed.
Show Segment Values: Shows all measurements available for the markup. When enabled, select an alignment for the measurements, either equal to the angle of the segments or horizontally.
Show Caption: Toggles the markup to show or hide the markup caption (as seen in the Preview Window).
