Polygon Sketch tool
Like the Polygon tool, the Polygon Sketch tool creates a shape with any number of sides as a markup; however, the length and rotation of the sides are input directly for exact control over the shape. Once placed, Polygon Sketch markups behave much like Polygon markups.
Before placing any Sketch markup on a drawing, make sure that it is calibrated to the correct scale.
Go to Tools > Sketch to Scale >
Polygon Sketch to Scale. The mouse cursor in the main workspace changes to the Polygon Sketch cursor and displays the measurements dialog.
- In the PDF, select where you want to place the first point. The text cursor is automatically placed in the Length field.
- Enter the length of the side of the polygon and press the Tab key on your keyboard.
- Enter the rotation of the side of the polygon and press the Enter key on your keyboard.
- The rotation can be relative to the last angle entered or to the page, as determined by the Sketch Tools Preferences.
- Repeat steps 3-4 to draw the remaining sides of the polygon.
- To automatically close the shape, do one of the following:
- Select the first point again to close the shape.
- Press Enter twice or press C on the keyboard to automatically close the shape by connecting the last point placed to the first point placed.
- Double-click when placing the last point to automatically close the shape by connecting the last point placed to the first point placed.
Control points define where line segments meet in a multi-segment markup. Add or remove control points to adjust the shape. See Working with Control Points for more information.
Convert line segments to curves or arcs at control points to match complex shapes. See Working with Curved Markups for more information.
Resize a segment or change its angle: Drag the appropriate yellow handle.
You can change the appearance of the Polygon Sketch Tool markup, including line and fill color, hatch pattern, line width and style, and opacity.
To change the appearance of a Polygon Sketch Tool markup, select the markup and select the Properties panel. Go to Window > Panels > Properties to show the Properties panel if it is hidden. Several properties will also be available on the Properties toolbar when the markup is selected.
Color: Sets the line color.
Show Segment Values: Shows all measurements available for the markup. When enabled, select an alignment for the measurements, either equal to the angle of the segments or horizontally.
Show Caption: Toggles the markup to show or hide the markup caption (as seen in the Preview Window).
Show Centroid: Marks the geometric center of the markup.
