Back up, reset, and restore Revu settings
It's important to back up your customized preferences, profiles, tool sets, and stamps for two key reasons:
- Data protection: Keep your settings safe in case of computer issues or hard drive failure
- Device transfer: Move your custom setup when you get a new computer
This article shows you how to back up your Revu 21 settings, transfer them to a new device, and restore them when needed.
Back up your preferences
Your preferences backup creates a .zip file with your Revu 21 settings. Even if you're not switching computers right now, it's a good idea to save this backup somewhere other than your local hard drive.
To back up your preferences, sign in to Revu 21 and follow these steps:
- Go to Revu > Preferences.
- On the left sidebar, select Admin.
- Under the Options tab, select Backup. Digital IDs and stamps aren't included in backup files and need to be transferred separately.
- Save the backup .zip file in an easy-to-access location.
Manual backup option
You can also back up the entire settings folder manually or add it to your backup routine. The folder is located at:
C:\Users\<UserName>\AppData\Roaming\Bluebeam Software\Revu\21
Back up profiles
Custom profiles contain your personalized tool configurations. To export them, follow these steps:
- Go to Revu > Profiles > Manage Profiles.
- Select the profile you want to export.
- Select Include Dependencies to include tool sets, bookmarks, hatch patterns, and line styles.
- Select Export.
- Save the profile .bpx file in an easy-to-access location.
- Repeat for any additional profiles you want to back up.
Back up tool sets
To export custom tool sets, follow these steps:
- Open the Tool Chest panel.
- Select the Settings icon at the far right of the panel for the tool set you want to export.
- Select Export.
- Save the tool set file in an easy-to-access location.
- Repeat for any additional tool sets you want to export.
Back up stamps
Custom stamps require manual file copying:
- Go to the Stamps folder in Windows File Explorer.
By default, your stamps are stored in one of the following locations, depending on your version of Revu: Revu 21.10 and later:
%AppData%\Bluebeam Software\Revu\21\StampsThis resolves to:C:\Users\<Username>\AppData\Roaming\Bluebeam Software\Revu\21\StampsIf the AppData folder isn't visible, you'll need to unhide it. In your <Username> folder, select View > Show > Hidden items.Revu 21 versions before 21.10 and Revu 20:C:\ProgramData\Bluebeam Software\Bluebeam Revu\<Version Number>\Stamps - Copy the Stamps folder to a new, easy-to-access location on your computer.
- Zip the copied Stamps folder.
If your stamps are not found here, they may have been moved. You can find their location in the Preferences menu:
- Select Revu > Preferences.
- Select the Net Config tab.
The Stamps field contains the location of your stamps. Navigate there via Windows File Explorer and copy your stamps to a safe location.
Back up advanced settings
If you've customized these advanced settings, back them up separately.
Bluebeam Printer custom page sizes
- Select Revu > Administrator.
- Double-click the file path next to Printer Driver.
- Copy the file
prtPages.xmlto your backup location.
Plugin custom page setups
- Double-click the file path next to Global Page Setup.
- Copy all
*.plugin.xmlfiles to your backup location.
Email templates
- Double-click the path next to E-mail Templates.
- Copy all files in the folder to your backup location.
Transfer settings to a new computer
Install Revu 21
- Download the latest version of Revu 21 here.
- Install Revu 21.
- Sign in with your BBID.
Import your settings
Make sure you have access to all your backed up files, then follow these steps:
Preferences
- On your new computer, go to:
C:\Users\<Username>\AppData\Roaming\Bluebeam Software\Revu - Replace the 21 folder with your backup folder (rename the backup folder to "21").
Profiles
- Open Revu.
- Select Import.
- Select your backed up profile .bpx files.
Tool sets
- Select Tool Chest > Manage Tool Sets.
- Select Import.
- Select your backed up tool set files.
Stamps
By default, your stamps are stored in one of the following locations, depending on your version of Revu: Revu 21.10 and later:%AppData%\Bluebeam Software\Revu\21\StampsThis resolves to:C:\Users\<Username>\AppData\Roaming\Bluebeam Software\Revu\21\StampsIf the AppData folder isn't visible, you'll need to unhide it. In your <Username> folder, select View > Show > Hidden items.Revu 21 versions before 21.10 and Revu 20:C:\ProgramData\Bluebeam Software\Bluebeam Revu\<Version Number>\Stamps - Replace the Stamps folder with your backup folder and unzip it.
Advanced settings
Copy your advanced backup files to the same locations you found them in on your original computer.
You may need to close and reopen Revu 21 for all your settings to load properly.
Restore your settings
You can restore your settings from a backup file to return to a previous configuration.
- Under the Options tab, select Restore, then click OK.
- Choose your Revu settings backup file and select Open.
Revu will close and reopen with your restored settings.
Reset your settings
If you're having issues with your current settings, you can reset them to original configurations. We recommend backing up your settings first.
- Under the Options tab, select Reset, then click OK.
Revu will automatically close and reopen with default settings.
Preferences
