Customize the navigation and status bars
The Navigation bar provides different options for viewing and interacting with your documents.
The Status bar displays information like page size and file properties, and includes buttons that affect cursor movement and markup placement.
Navigation bar
The Navigation bar is divided into three sections based on function:![]()
- From the left side, you can use the MultiView options to view multiple documents or multiple views of a single document.
- From the center, you can switch between panning, zooming, selecting, and changing pages or views in the document.
- From the right side, you can access miscellaneous options (depending on your profile settings) such as the Profiles menu, the Dimmer, document properties, or document security settings.
How to hide and reveal the Navigation bar
To toggle the Navigation bar, use the F4 key. Alternatively, you can go to Tools > Toolbars > Navigation Bar.
Status bar
The Status bar appears under the Navigation bar. ![]()
On the left side of the Status bar, you'll see an area that contains context-sensitive text. If no files are open in Revu, the text will read "Open PDF to markup." Once you open a PDF, the text will change to "Ready." When you select a markup, you will see context-sensitive help from this area. If you're ever unsure how to use a markup, look to this corner for help.
On the right side of the Status bar, you'll see the Snap To settings, the page dimensions of the current file, the page scale, and the coordinates for your cursor position.
You can learn more about
Snap To Grid,
Content, and
Markup, as well as other Status bar tools in the Revu Help.
Show Grid displays a dotted grid over your open document. This grid assists with markup placement and measurements.
Reuse allows you to repeatedly use a markup or tool from one of your tool sets.
Synchronize Views is a function used with MultiView and MultiView Extended. After you open different versions of a document in separate Revu tabs, activate
Synchronize Views to synchronize the view of your active tab with the other versions of the document. This function allows you to compare different versions of the same page region. For more information, read How to split, sync, and unsplit views.
To enable any of these features, select the corresponding icon in the Status bar. Selected icons will be highlighted in blue, indicating that they're active. Click a highlighted button to deactivate it.
How to hide and reveal the Status bar
To toggle the Status Bar, use the F8 key. Alternatively, you can go to Tools > Toolbars > Status Bar.
More information
This article is part of the Customizing Bluebeam Revu series:
| Introduction | General Preferences |
| Panels | Main Workspace and Menu Bar |
| Navigation and Status Bars | Toolbars |
See also:
- Revu Help - Complete documentation of all Revu features and functions.
Interface & Navigation
