Revu registration errors
One of the error messages shown below appears when attempting to register your Bluebeam software.
Check your license certificate
The first thing you should do is confirm that the software edition (Standard, CAD or eXtreme) and version number shown in the Registration dialog box, along with the serial and product key you've entered matches what's listed in the License Certificate that was sent from registration@bluebeamops.com.
If you're unable to find your license information, see Find your Revu product key.
Common Revu registration errors
The serial number and product key could not be validated
The number of authorized installations has been exceeded
You have entered a serial number for a different edition
The serial number and product key entered is for an older version of this product
An online connection could not be established. Please select 'Get Authorization Code Manually'...
Error Message
Licensing & Registration
