Error: "Unable to find a Project or Session with ID"
When trying to access a Project or Session you've been invited to, you receive the error "Unable to find a Project or Session with ID: XXXXXXXXX."
Cause
Studio UK and Studio US servers
The most common reason for this error is trying to access a Project or Session that's on a different Studio server than the one you're currently logged into. Bluebeam has a Studio server instance in the US (studio.bluebeam.com), and another in the UK (bluebeamstudio.co.uk).
Due to data law restrictions, the data stored in these servers must be kept separate, meaning Studio US accounts can't access Studio UK, and vice versa. This means that if someone sends you an invitation to join a Project or Session, you'll need to use a BBID that was created on the same Studio server where the Project or Session was created.
Private Studio Enterprise servers
This error may occur if the Project or Session you're trying to access was created on a company's private Studio Enterprise server while you're signed in to the Studio US or UK server.
It can also occur if the Project or Session you're trying to access was created on the Studio US or UK server while you're signed in to a company's private Studio Enterprise server.
Session or Project has been removed
If you try to access a Session or Project that has been archived, removed by its owner, or is expired, you'll receive this error.
If you need access to both Studio US and UK, you'll need to create a BBID for each server.
To set your default Studio server
- Go to Revu >
Preferences.
- Select Studio from the sidebar.
- Go to the Servers tab, and select your preferred server from the Current Server dropdown.
If you're trying to access a Project or Session that was created on a private Studio Enterprise server, you'll need an account on that company's Studio Enterprise server.
If you're signed into a private Studio Enterprise server but are trying to access a Project or Session that was created on the Studio US or UK server, see the articles mentioned in the previous solution to change your Studio server.
If you're trying to access a Session or Project that has been removed, you'll need to contact the Session or Project owner.
If you're the owner of an archived or expired Session and need to access its documents, you're still able to recover deleted Studio Session documents. If you're the owner of a deleted Studio Project, it will remain recoverable for up to 120 days after deletion. After 120 days, the Project is permanently deleted from the server. If you want to recover a deleted Studio Project, please contact us within the stated time frame to ensure the Project is recoverable.
Error Message
