Page setup
The Page Setup feature in Revu allows for the resizing of pages in a PDF file. In addition to scaling a drawing up or down, this tool can also be used to add borders to PDFs (for example, for binding purposes as shown in the Resizing PDF Pages Tutorial). Using the Page Setup feature modifies the PDF file, therefore it cannot be used on PDF/A documents or documents that have been certified or digitally signed.
Resize pages and page content
Go to Document >
Page Setup.
- To use a previously saved batch of PDFs, select Load and select the desired file.
- Revu automatically adds active PDFs to the process. To add more PDFs, select Add and use one or more of the following methods:
- Files: Adds individual files from a network or local drive. Selecting this option causes the Open dialog to appear. Navigate to the appropriate location and select the desired files.
- Open Files: Adds all files currently open in Revu.
- Open Set: Adds all files contained in the current Set.
- Folder: Adds all files in a selected folder on a network or local drive, but not files contained in any of its subfolders. Selecting this option causes the Select Folder dialog to appear. Navigate to the desired folder and select it.
- Folder and Subfolders: Adds all files in a selected folder on a network or local drive as well as all files within any of its subfolders. Selecting this option causes the Select Folder dialog to appear. Navigate to the desired folder and select it.
- By default, any document in the Files list will be affected. To remove a document from the Files list, select it then select Remove.
- PDFs are processed in the order they appear in the Files list. Drag and drop files to change the order.
- To specify which pages of a PDF will be processed, select it, then select the Pages menu and select one of the following options:
- Current: Sets the range to the current page only.
- Current View: Limits the process to the current zoom.
- Even Pages: Limits the process to only even pages.
- Odd Pages: Limits the process to only odd pages.
- Landscape Pages: Limits the process to only landscape-oriented pages.
- Portrait Pages: Limits the process to only portrait-oriented pages.
- To save this batch for future use, select Save and save the batch to a local or network drive.
Select Next. The Crop and Page Setup dialogappears with the Page Setup tab selected.
The Preview section on the right shows the current media size as well as the size of the drawing and its scale.
- To change the paper size, select an option from the Media Size dropdown menu. The paper size setting corresponds with the paper size that the drawing is to be printed on, even if it is not to be printed. If you enable Auto Scale, the drawing will automatically scale up or down to fit the new media size, as appropriate.
Media Size allows you to select Custom Page Size to define a custom size, specify Portrait or Landscape orientation, and set the Widthand Height fields. - Adjust the Scale manually, as desired.
- To adjust the drawing on the page along the X or Y axis, set the Offset X or Y values appropriately.
- To rotate the drawing on the page, set the Rotation. To set the Rotation according to a line on the drawing:
- Select Get Line.
- Drag the desired line on the drawing.
- To reset the Offset, Scale, and Rotation settings, select Clear.
- To center the drawing, select Center.
- To fit the drawing to the media, select one of the alignment options from the Fit to Media dropdown menu.
Determine the page range to resize from the Pages dropdown menu.
- Current: Sets the range to the current page only. The current page number will appear in parentheses, for example, Current (2) if page 2 is the current page.
- Selected: Sets the range to the current selection. This option only appears if pages were selected prior to invoking the command.
- Select OK.
