Collaborate in Studio with teammates who don't own Revu
- Bluebeam on web and mobile
If you have a team member who doesn't own Revu, but you want to invite them to a Studio Project or Session, you can by having them use one of the following:
- Revu 20 in View mode
- Revu 21 in Read-only mode
- Bluebeam on web and mobile in Read-only mode
There are two sides to Studio: Studio Projects and Studio Sessions. This article will help you figure out which is best for the collaboration needs of your team, and how you and your team members can participate in both.
- Collaborate using Studio Sessions
- Collaborate using Studio Projects
- Collaborate using Studio Sessions in Bluebeam on web and mobile
Work in Read-only or View mode
- For Revu 21, download and install Revu 21 on your computer.
- For Bluebeam on web and mobile, create a Bluebeam ID (BBID).
After your free trial expires, Revu 21 and Bluebeam on web and mobile will be in Read-only mode if you don't have an active Bluebeam plan. For more information, see this article.
Other reasons for having Read-only access include:
- You haven't been invited as an End User yet and will need to contact your Org Admin.
- You've been invited as an End User but haven't yet accepted the email invitation and activated your account.
- The Org Admin for your Bluebeam plan has assigned you Read-only access. You'll need to contact your Org Admin to request a subscription invitation.
- If you're an Org Admin, you may need to assign yourself End User permissions and modify subscription access to add your account to a Bluebeam plan.
- For Bluebeam on web and mobile, your Org Admin has assigned you to a Basics subscription plan, which defaults to Read-only permissions.
Download and install Revu 20 on your computer. When the installer asks you to enter your serial number and product key, select Use as Trial. This will activate a trial of Revu, granting you full access to the software. Once the trial ends, Revu will automatically switch View Mode. To switch to View Mode at any time, select Revu > View Mode.
Studio Sessions are for PDF-based online collaboration.
While in a Session, there is no need to check files in and out. You can select a PDF to open it, even if other users have the PDF open. All users in a Session can mark up the document, and everyone can see what others are adding or have added. There's a record that captures user activity, including the username and what they added, modified, or removed from the PDF.
Add and edit markups
All markups are added in real time and uploaded to the cloud as you add them to the PDF. Even if you lose connection to the Session, your markups are stored safely in the cloud within that Session. Revu will remember which PDFs you had open and will restore them automatically, so you can pick up where you left off once internet connectivity is restored.
To maintain user accountability, markups can only be edited or removed by the user who initially created them.
Studio Projects is the Bluebeam document management system that lets you store many different file types (like PDFs, Microsoft Office files, and images) in the cloud. As a user in View or Read-only mode, you may only view Project files. However, if you need to add markups to a PDF in the Project, the Project owner (the person who invited you to the Project) can add the PDF to a Session. Alternatively, the Project owner can use the Share Link feature, which allows you to download a local copy of the Project file.
Add Project documents to a Session
The Project owner can right-click the PDF document and add it to a new Session. The owner can give this ability to other users in the Project via Permissions as well. Once the PDF is added to a Session, a user in View or Read-only mode can access that Session as before, using either an invitation link or the Studio ID number.
Share a link to a Project file
As the Project owner, follow these steps:
- Right-click the file, and select Share Link.
- Specify how long the download link should be active, and whether you want to require a password.
- Select OK.
Revu generates a hyperlink that you can copy and distribute. Users in View or Read-only mode will be able to download the file from this link.
Work with non-PDF files in Projects
You can also upload other file types, such as Excel spreadsheets and Word documents, to Studio Projects. These files may be checked out and edited locally using the appropriate application, then checked back into the Project.
- Right-click the file, and select Check Out.
- Right-click the file again, and select Open.
- Edit the document in the application that opens, and save your changes as you normally would.
- Back in the Project, right-click the file listed in the Pending section, and select Check In.
Recover Studio files
If you lose internet connectivity after you check out a file, you should see your activity in the Pending Changes section. Once you connect to the internet again, pending changes will save to the Project file.
Bluebeam on web and mobile users with Read-only access can use Studio Sessions to view and markup PDFs. For more information, see Bluebeam on web and mobile in Read-only mode.
As a user with a Core, Complete, or Max plan, select the
Studio Sessions tab in Bluebeam on web and mobile, and do one of the following:
- Select Create to create a new Studio Session and add the Read-only user as an attendee.
- Open an existing Studio Session, select Share, and add the Read-only user as an attendee.
As a Read-only user, open the email inviting you to the Studio Session.
- If you already have a BBID, select Join Session.
- If you do not have a BBID, select Create Account, follow the prompts to create your account, then return to the email and select Join Session.
- When prompted to choose how to join the Session, select Join in the Web.
