Typewriter tool
The Typewriter tool is useful for entering information into form-like PDFs where rows are regularly spaced. The Typewriter tool also allows you to enter text without having to define a text box.
- Select the Typewriter tool using one of the following methods:
- Go to Tools > Markup >
Typewriter. - Select
on the Text toolbar. - Press W on the keyboard.
- Select a place on the document to begin typing.
Delete.
The Appearance Properties for the Typewriter tool are generally the same as those for the Text Box Tool, though the default Font is Courier to better match the style of a typewriter. The most common thing that needs to be adjusted in a Typewriter markup is the amount of space between rows of text in order to fit properly on a form. To do so, change the Line Space setting.
To change the appearance of a Typewriter markup, select the markup and select the Properties panel. Go to Window > Panels > Properties to show the Properties panel if it is hidden. Several properties will also be available on the Properties toolbar when the markup is selected.
The Appearance section of the Properties panel contains the following options:
Color: Sets the color of the text box and leader line, if any.
Fill Color: Controls the fill color of the text box.
Opacity: Sets transparency level for the text box and the leader line.
Fill Opacity: Sets transparency level (100 = opaque, 0 = completely transparent) for the fill color.
Line Width: Sets the thickness of the line segment in points. If the Line Width is set to 0, it is effectively invisible.
Style: Determines the pattern of the line segment. The Cloud style only affects the text box; the leader line (when applicable) is solid. Any styles other than Cloud affects both the text box and the leader line.
Size: Sets the width of the cloud segments. Only applies when Style is set to Cloud.
Invert: Inverts the cloud segments inward on the shape. Only applies when Style is set to Cloud.
Shape: Sets the shape of the text box. Options include Rectangle, Circle, Triangle, and Hexagon. Note that if no Line Width has been set for the text box and the shape is changed, the line width is automatically set to "1.00". This can be changed afterward, if needed.
End: This setting is grayed out because it does not apply to Typewriter markups.
Auto: Automatically adjusts the font size of the text to the maximum value that will fit in the text box.
Line Space: Adjusts the spacing between multi-line rows of text.
Margin: Defines the amount of space between the text characters and the border of the Text Box.
Alignment: Defines the alignment of text within the box. The icons represent Left, Center, Right, Top Justified, Middle Justified and Bottom Justified respectively.
