Bluebeam Gateway guide
What is the Bluebeam Gateway?
The Bluebeam Gateway is an online administrative portal available for Revu 20 & below licenses with active Maintenance. Gateway admins (also called license admins) can make changes to their Bluebeam accounts, manage other Gateway admins, and more.
The Gateway is arranged into two sections:
- Revu Licenses– View and manage your Perpetual, Enterprise and Open licenses.
- Gateway Admins – Set permissions for admins on the account.
Access the Gateway
The Bluebeam Gateway is fully accessible online at https://portal.bluebeam.com and admins can perform account-related tasks there.
Sign In
You need your Bluebeam ID (BBID), the same credentials used for signing into Bluebeam Studio.
To sign in to the Gateway, follow these steps:
- Go to https://portal.bluebeam.com
- Under Bluebeam ID, enter your BBID email and password.
- Select Sign In.
If you have multiple accounts
In the Gateway homepage, you'll see an overview of your accounts and associated licenses. Use the search bar to quickly find the account you're looking for.
Account Summary
Selecting an account takes you to the Account Summary page. This is where you'll see Revu licenses and active Gateway admins. From here, you can manage the account by going to one of the sections discussed below.
Revu Licenses
Selecting Revu Licenses takes you to the Manage Licenses page, where you can select a tab (Perpetual, Enterprise, or Open) and view an account's licenses. Switch between different license types by selecting the tabs at the top. If a tab isn't visible, it means that license type isn't associated with your account. If you have questions, see Questions about Licensing and Installation.
Perpetual Licenses
In this tab, you'll see a tabulated view of all Perpetual Licenses associated with your account. Each license is identified by its unique serial number and the table can be sorted by Registered Seats, Maintenance Expiration, Version, and more. To sort these results even further, select an edition of Revu at the top. Selecting a serial number takes you to the Details page for that license.
Search by computer name
If you don't know the serial number for a license, you can search by its computer name. To do this, select the Computer Name option in the search bar.
Details page
The Details page is where you can see all information for your license, such as:
- Product Key
- Maintenance
- Available Seats
- Version
- IP Address
- Registered Date
Export License Information
You can export all data for a license by selecting the Download the .csv.
Enterprise License
In the Enterprise Licenses tab, you'll see a tabulated view of all Enterprise Licenses associated with your account. Each license is identified by its unique serial number and sorted by Registered Seats, Maintenance Expiration, Version and more. To sort these results even further, select an edition of Revu at the top. Selecting a serial number takes you to that license's Details page.
Details page
The Details page is where you can see all information for an Enterprise License:
- User
- Version
- Product Key
- Registered Seats
- Available Seats
- Maintenance
- Last Ping
Registered tab
The Registered tab lists all computers currently registered to the selected license. You can also see other details such as IP address, the date the computer was registered, and Last Ping (the last time Revu was accessed on the device).
Selecting the checkbox next to each computer reveals the Revoke Computer button. Revoking a registered computer releases it from the license and forces the removal of all license info from that computer.
You can cancel a Pending revoke request by clicking Cancel Revoke in the following page. Once the status has changed to Successfully Revoked, machines will need to be re-registered manually.
Revoked Tab
This tab lists all unregistered computers, along with the Computer Name, Version number, Revoked Date, and Last Ping (the last time Revu was accessed on the device).
Open License
In the Open Licenses tab, you'll see a tabulated view of all Open Licenses associated with your account. Each license is identified by its unique serial number and sorted by Seats that are Allowed or In Use, and the total number of Available Seats. Selecting a Serial Number takes you to that license's Details page. Learn more about how Seats are managed in the Revu Administration Guide.
Details Page
The Details page is where you can see all information for a license, such as product keys for all versions, computer names, users, seats allowed, Maintenance status, and Last Ping (the last time Revu was accessed on the device).
The middle of this page shows a Usage Report section that includes a graph detailing the license's usage history. The Devices on This License section displays information about devices that have accessed the Open License.
Select to download an Excel spreadsheet with license information.
Usage Report
The Usage Report allows you to visualize data trends and examine license access in greater depth. There are a few ways to filter the data:
- Active Users: When selected, this option displays the number of active users on the graph.
- Active and Denied Users: When selected, this option displays the number of Active and Denied users on the graph.
- Date dropdown: Use this dropdown to change the data that appears in the graph, and in the user data spreadsheet mentioned previously. You can select preset date ranges or use the Custom Date Range option.
- Export license information: Select Download the .csv to download an Excel spreadsheet containing detailed information about user access to the Open License. The date range included in this spreadsheet is determined by the dates displayed in the graph.
To create a custom date range:
- Select the downward arrow above the graph.
- Select Custom Range at the bottom of the list.
- Select the date field on the left to choose a start date.
- Once the calendar appears, select a date.
To select a different month, click the current month name to enter the monthly view.
To select a different year, click the back arrow when you're in day view. - Next, select the date field to the right and select an end date using the calendar.
- Select Apply.
The graph illustrates trends based on three statistics:
- Allowed: The number of users allowed to access Revu at the same time. This number is represented by a yellow dotted line.
- Denied: The number of users denied access to Revu at a particular time, indicating that the number of Allowed users was exceeded. This number is represented by a red dot. Make sure to select Show Denied box if you want to display this information.
- Max Active: The total number of users who accessed Revu at a particular time. This number is represented by a blue dot.
You can also interact with the graph to see more detailed information:
- Hover over the graph to see exact numbers for a particular time. A tooltip adjacent to the dot your cursor is on will display the exact numbers in their associated colors. A tooltip will also display the indicated time at the bottom of the graph.
- To view a smaller data set, click and drag over your intended range, then release. The graph will zoom in on that range. Double-click the graph to zoom out.
This portion of the license page lets you see all the devices that have access to the Open license or had access in the past. This information is organized into the following tabs: Active, Registered, and Revoked.
Active Tab
This tab displays a list of the computers that are currently running Revu and is where you can temporarily release a seat currently in use by one of the listed machines. Releasing a seat on your Open License allows another computer to open Revu, take the released seat, and use Revu with full functionality.
To release a seat, select the box next to the computer name and click Release Selected. Releasing a seat doesn't revoke the license registration for the computer, and it will still appear on the Registered tab.
This is a temporary action and any computer released in this way will reacquire its seat within the next 20 minutes, so it's important that Revu is opened on the new computer soon after the seat release occurs. Otherwise, the seat will be reclaimed by the original computer and there will be no available seats for other machines.
After the released seat is successfully acquired by a new computer, the original PC that was released will still be able to obtain a seat even if all seats are occupied. This ensures that a user is never in a position where they are unable to save their work. In this situation, you may notice there is a negative seat balance on your license. This will correct itself once another user closes Revu and releases their seat.
The ability to release and reassign seats between computers using our legacy licensing system is no longer available. As of the dates listed below, legacy versions have been removed from our support site and are no longer available for download. If you need a copy for archival, please download it before the date listed below or contact us afterward for a direct download link along with a copy of your original license certificate. After these dates, you'll no longer be able to reassign or transfer legacy licenses between computers.
Revu 2015 and earlier: May 12, 2026
Revu 2016–2019: June 23, 2026
Revu 20: July 31, 2026
Licenses already activated will continue to work on the computers they are installed on. As of the dates above, those licenses cannot be transferred to a new or replacement computer. If you replace or upgrade hardware, you'll need a Bluebeam subscription plan to continue using Revu.
For more information, see Bluebeam End of Life (EOL) Support.
Registered Tab
This tab displays a list of registered computers, along with the product version number, IP address, original registration date, and Last Ping (the last time Revu was accessed on the device).
If you need to unregister a computer, select the box next to the computer name, click Revoke Selected, and then click Revoke Devices on the next page that opens to confirm the revocation.
Revoked Tab
This tab displays a list of unregistered computers, along with the version number, revoke status, and the time when it was last used.
To cancel a pending revoke request, select Cancel Revoke next to a device listed on the Revoked tab. Machines will need to be re-registered manually once the Revoke Status has changed to Successfully Revoked.
Gateway Admins
If you want to have a colleague help with your license administration, you can add them as a Gateway admin (also called a license admin). Admins are able to view all licenses within an account and manage other Gateway admins.
From the homepage, select Manage Gateway Admins. This takes you to the View and Manage Gateway Admins page that shows a tabulated view of Current Admins and Deactivated Admins.
Current Admins tab
To see the current Gateway admins for an account, select the Current Admins tab. This displays a tabulated list of admins. In this tab, you can also Invite or Deactivate an admin.
Invite a Gateway admin
To invite a new admin, select the Invite Gateway Admin button at the top. Enter the new admin's BBID email and select Send Invite. The user will receive an email with next steps.
Deactivate a Gateway Admin
To deactivate an existing admin, search for their BBID email in the admin list and select Deactivate.
Deactivated Admins Tab
Select this tab to see a list of deactivated admins. To reactivate an admin, search for their BBID email and select Make Admin. The user will receive an email with next steps..
Additional Gateway Features
You can access additional features in the Gateway footer:
- Reset Password: This takes you to a BBID reset password page.
- Change Email: This takes you to a BBID change email page.
- Contact Us: This brings you to the Contact Us page, where you can send a message to our Account Services or Technical Support team.
- Download Revu: This takes you to the Updates and Installation page, where you can download our latest product updates.
