Transfer your license to a new computer
The ability to release and reassign seats between computers using our legacy licensing system is being phased out. After the dates listed below, legacy versions will be removed from our support site and will no longer be available for download. If you need a copy for archival, please download it before the date listed below or contact us afterward for a direct download link along with a copy of your original license certificate. After these dates, you'll no longer be able to reassign or transfer legacy licenses between computers.
Revu 2015 and earlier: May 12, 2026
Revu 2016–2019: June 23, 2026
Revu 20: July 31, 2026
Licenses already activated will continue to work on the computers they are installed on. After the dates above, those licenses cannot be transferred to a new or replacement computer. If you replace or upgrade hardware, you'll need a Bluebeam subscription plan to continue using Revu.
For more information, see Bluebeam End of Life (EOL) Support.
You need to have both your serial number and product key ready to complete this process. They can be found on the License Certificate sent to the license owner from registration@bluebeamops.com. If you're unable to find your license information, see Retrieve your Revu product key.
Back up and restore settings
- To back up your tool sets and profiles, see Back up, reset, and restore Revu settings.
- To back up and import your stamps, see Back up and restore your stamps.
Before you begin, make sure the source computer you're transferring from has a stable internet connection.
On the source computer
- Open Revu.
- Go to Revu > Unregister.
- Close Revu.
To uninstall Revu and the OCR module, see Microsoft's page about uninstalling apps and programs from Windows.
On the destination computer
If Revu is already installed on your new computers
- Open Revu.
- Go to Revu > Register.
- Enter your serial number and product key from your License Certificate.
- Select Register.
If Revu is not yet installed on your computer
- Download Revu. Make sure you download the same version listed in your License Certificate.
- Run the installer.
- Enter your serial number and product key when prompted.
You may need to restart Windows before relaunching Revu. Save your work and close any running applications before you restart.
For help with possible errors during the registration process, see Revu registration errors for a list of common solutions.
Setup
Installation
Licensing & Registration
