Line tool
The Line tool draws a straight line segment. Segments can be at any angle and easily forced to be horizontal, vertical, or at a 45° angle on the page.
- Select the Line tool using one of the following methods:
- Go to Tools > Markup >
Line. - Select
on the Shapes toolbar. - Press L on the keyboard.
- Drag to place a line segment on the PDF.
Tips:
Delete.
Resize the markup or change its angle: Drag the appropriate yellow handle. Hold Shift while dragging to force the markup to a horizontal, vertical, or 45° angle.
The appearance of the Line markup is configurable, including its color, thickness, pattern, ends, and opacity.
To change the appearance of a Line markup, select the markup and select the Properties panel. Go to Window > Panels > Properties to show the Properties panel if it is hidden. Several properties will also be available on the Properties toolbar when the markup is selected.
Color: Sets the line color.
Fill Color: Controls the fill color of the endpoints.
Highlight: Makes the fill color and line transparent so underlying content shows through.
Start and End: Controls the appearance of the endpoints for each side of the line. The diagram below shows samples of each type of endpoint.
Each endpoint has an associated Scale that determines the size of the endpoint in relation to the Line Width. By default, it is set to Auto and will automatically adjust as the Line Width is changed.
