Arc tool
The Arc tool places an arced markup on the document. There are three basic arcs that can be created in Revu: an elliptical arc, a two-point circular arc, and a three-point circular arc. Giving an arc a fill color or hatch pattern automatically turns it into a pie shape.
- Select the Arc tool using one of the following methods:
- Go to Tools > Markup >
Arc. - Select
on the Shapes toolbar. - Press SHIFT+C on the keyboard.
- To create an elliptical arc:
- Click on the document to place the first point of the arc.
- Click again to place the end point.
- To create a two-point circular arc:
- Hold down the SHIFT key.
- Select both points of the arc.
- To create a three-point circular arc:
- Hold down the ALT key.
- Select the first point of the arc.
- Select the second point to define the circle.
- Select the third point to complete the arc.
Delete.
To resize the markup, drag the appropriate yellow handle. When dragging the control handles at the endpoints of the line, the arc will automatically continue on its original ellipse. To automatically lengthen or shorten the arc in 15° increments, hold down SHIFT while dragging.
The appearance of the Arc markup is configurable, including its line and fill color, hatch pattern, line width and style, and opacity. Selecting a Fill Color or Hatch pattern will automatically turn the arc into a pie shape.
To change the appearance of an Arc markup, select the markup and select the Properties panel. Go to Window > Panels > Properties to show the Properties panel if it is hidden. Several properties will also be available on the Properties toolbar when the markup is selected.
Color: Sets the line color.
Style: Determines the line pattern.
In addition to the standard line styles, there are several advanced styles and you can create Custom Line Styles, if desired.
