Deployment archive
Deployment packages offer administrators the flexibility to silently install Bluebeamproducts to multiple computers in an automated fashion.
Versions
The current version is available on the Revu Deployment Packages page.
Contact Bluebeam Support if you need a version that's not provided here.
20.3.20
Premium Support
Premium technical support includes troubleshooting assistance and answers to questions about basic workflows and product features via email.
The following documents have been prepared to help you deploy, run and update your Bluebeam software. For the best results, we strongly recommend reading both guides and the readme before beginning your deployment.
  • The Revu 20 Deployment Guide describes how Bluebeam can be deployed and utilized in an enterprise setting. Typically, large organizations face unique challenges when implementing desktop applications, such as finding the most efficient deployment and configuration methods when using multi-user settings within a network environment.
  • The Revu 20 Administration Guide covers how to manage and troubleshoot your installations on a day-to-day basis, after you've completed a deployment.
  • A readme file is included with each download that contains additional information about how to install or update the software.
MSP Update Files for Revu
As of Revu 20, MSP files will no longer be used for patching existing installations of Revu. Each new update will now be applied by pushing out an MSI file. However, you'll still be able to update older versions of Revu (2016-2019) with the MSP files located here.
MSI Installation Files for Revu
Parameters can be passed at the command line or configured through an MSI editor.
Revu: These packages include all three Revu editions: Standard, CAD, and eXtreme. For more information about installing MSI packages, click here.
64-bit MSI installation: English and International
32-bit MSI installation: English and International
2019.1.20
Legacy Support
Legacy technical support includes answers to questions about basic workflows and product features via email
  • The Revu 2019 Deployment Guide describes how Bluebeam can be deployed and utilized in an enterprise setting. Typically, large organizations face unique challenges when implementing desktop applications, such as finding the most efficient deployment and configuration methods when using multi-user settings within a network environment.
  • The Revu 2019 Administration Guide covers how to manage and troubleshoot your installations on a day-to-day basis, after you've completed a deployment.
To reduce the installation time, this Revu update uses a smaller MSP file instead of the full MSI installer.
This MSP update can only be installed on Revu 2019.0 through Revu 2019.1.16. Updating older versions requires the full MSI installation.
The update process may cause a forced reboot, so please make sure all work is saved and all open applications are closed before the update is started.
64-bit MSP update: English and International
32-bit MSP update: English and International
Revu: These packages include all three Revu editions: Standard, CAD, and eXtreme. Follow the steps described in the Revu Enterprise Installation Guide for selecting the edition and registering the installations.
Use the MSP update above if you are updating Revu 2019.0 through Revu 2019.1.20.
2018.6
Legacy Support
  • The Revu 2018 Deployment Guide describes how Bluebeam can be deployed and utilized in an enterprise setting. Typically, large organizations face unique challenges when implementing desktop applications, such as finding the most efficient deployment and configuration methods when using multi-user settings within a network environment.
  • The Revu 2018 Administration Guide covers how to manage and troubleshoot your installations on a day-to-day basis, after you've completed a deployment.
This MSP update can only be installed on Revu 2018.0 through Revu 2018.5. Updating older versions requires the full MSI installation.
Parameters can be passed at the command line or configured through an MSI editor. Deployments can be handled by various methods, as described in the Revu Enterprise Installation Guide.
Use the MSP update above if you are updating Revu 2018.0 through Revu 2018.5.
2017.0.40
Legacy Support
  • Revu Enterprise Installation Guide describes how Bluebeam can be deployed and utilized in an enterprise setting. Typically, large organizations face unique challenges when implementing desktop applications, such as finding the most efficient deployment and configuration methods when using multi-user settings within a network environment.
  • The Bluebeam Revu Enterprise Administrators Guide covers how to manage and troubleshoot your installations on a day-to-day basis, after you've completed a deployment.
To reduce the installation time, this Revu update uses a smaller MSP file instead of the full MSI installer. The Revu Enterprise Installation Guide contains detailed instructions for this process.
This MSP update can only be installed on Revu 2017.0.8 through Revu 2017.0.30. Updating earlier versions requires the full MSI installation.
64-bit MSP update:English and International
MSI Installation Files for Revu & Vu
Use the MSP update, available above, if you are updating Revu 2017.0.8 through Revu 2017.0.30.
Vu: The full installation is used to update Vu.
2016.5.2
Legacy Support
This MSP update can only be installed on Revu 2016.5 or Revu 2016.5.1. Updating earlier versions requires the full MSI installation.
MSI Installation Files Revu & Vu
Revu: These packages include all three Revu editions: Standard, CAD, and eXtreme. You will need to follow the steps described in the Revu Enterprise Installation Guide for selecting the edition and registering the installations.
Use the MSP update, available above, if you are updating Revu 2016.5 or 2016.5.1.
Setup
Legacy
Deployment
Enterprise
Need to deploy an older version of Revu? You can find MSI and MSP packages here.
