Rectangle tool
The Rectangle tool places a rectangular markup on the document. Holding down the SHIFT key will cause the rectangular markup to automatically form a square. The use of the Rectangle tool is nearly identical to that of the Ellipse tool.
- Select the Rectangle tool using one of the following methods:
- Go to Tools > Markup >
Rectangle. - Select
on the Shapes toolbar. - Press R on the keyboard.
- Drag to define the size of the rectangle. Or, select two points to define the opposite corners of the shape.
Tips:
- Hold down SHIFT while defining the shape to force the shape into a square.
Delete.
- Use the side control handles (yellow squares) to stretch or compress the markup in a single direction.
Use the corner control handles (yellow circles) to scale the markup up or down in multiple directions.
- Hold down SHIFT while dragging a corner control handle to force the shape into a square.
The appearance of the Rectangle markup is configurable, including its line and fill color, hatch pattern, line width and style, and opacity.
To change the appearance of a Rectangle markup, select the markup and select the Properties panel. Go to Window > Panels > Properties to show the Properties panel if it is hidden. Several properties will also be available on the Properties toolbar when the markup is selected.
Color: Sets the line color.
Style: Determines the line pattern.
In addition to the standard line styles, there are several advanced styles and you can create Custom Line Styles, if desired.
