Cloud+ tool
The Cloud+ tool creates a Polygon markup with a cloud-like appearance and callout box preset. It is essentially the Cloud Tool and the Callout Tool combined into one tool. It appears as a single markup in the Markups list.
- Select the Cloud+ tool using on the following methods:
- Go to Tools > Markup >
Cloud+. - Select
on the Shapes toolbar. - Press K on the keyboard.
- To create a rectangular cloud:
- Drag on the PDF to create the cloud.
- Click again to place the callout text box.
- To create a polygonal cloud:
- Select a place on the PDF to define each point of the cloud shape. To remove the last point placed, press BACKSPACE.
Finish the cloud shape using any of the following methods:
- Select the first point again to close the shape.
- Press Enter twice or press C on the keyboard to automatically close the shape by connecting the last point placed to the first point placed.
- Double-click when placing the last point to automatically close the shape by connecting the last point placed to the first point placed.
- Select again to place the callout text box.
- Enter the desired text in the text box. Press ALT+Z to autosize the text box to fit the text.
- Click away from the text box or press ESC to finish
Tips:
- Hold down SHIFT while placing a polygonal cloud to draw lines that are at horizontal, vertical, or 45° angles.
- Hold down SHIFT while placing a rectangular cloud to force the shape into a square.
Delete.
Control points define where line segments meet in a multi-segment markup. Add or remove control points to adjust the shape. See Working with Control Points for more information.
Convert line segments to curves or arcs at control points to match complex shapes. See Working with Curved Markups for more information.
To move only the text box, select inside the text box and drag it to the desired location. Alternatively, drag the leader line (not its handles).
The text box's leader line will automatically move along the cloud's edge.
To autosize the text box so that it fits the text, right-click it and select Autosize Tex Box, or select it and press ALT+Z.
To move the entire markup together, drag the cloud part of the markup.
To move only the cloud, hold down the ALT key while moving the cloud. The text box will not move, but its leader line will automatically adjust to stay connected to the cloud.
To move the leader origin from one side of the markup to another, drag the leader line's bend (or "knee") control handle to the desired side.
The appearance of the text, text box, leader line, and cloud shape of a Cloud+ markup are all configurable. The appearance settings of the cloud portion of the markup and the callout portion are independent.
To edit the appearance of a Cloud+ markup, select the markup and select the Properties panel. Go to Window > Panels > Properties to show the Properties panel if it is hidden. Several properties will also be available on the Properties toolbar when the markup is selected.
The properties of a Cloud+ markup are split up into two sections, one for the cloud and one for the callout.
Cloud section
Color: Sets the line color.
When Style is set to Cloud, the Size and Invert settings are also available.
Size: Sets the width of the cloud segments.
Invert: Inverts the cloud segments inward on the shape.
Size = 2.00
Size = 1.00 and Inverted
Callout section
Color: Sets the color of the text box and leader line, if any.
Fill Color: Controls the fill color of the text box.
Opacity: Sets transparency level for the text box and the leader line.
Fill Opacity: Sets transparency level (100 = opaque, 0 = completely transparent) for the fill color.
Line Width: Sets the thickness of the line segment in points. If the Line Width is set to 0, it is effectively invisible.
Style: Determines the pattern of the line segment. The Cloud style only affects the text box; the leader line (when applicable) is solid. Any styles other than Cloud affects both the text box and the leader line.
Size: Sets the width of the cloud segments. Only applies when Style is set to Cloud.
Invert: Inverts the cloud segments inward on the shape. Only applies when Style is set to Cloud.
Shape: Sets the shape of the text box. Options include Rectangle, Circle, Triangle, and Hexagon. Note that if no Line Width has been set for the text box and the shape is changed, the line width is automatically set to "1.00". This can be changed afterward, if needed.
Auto: Automatically adjusts the font size of the text to the maximum value that will fit in the text box.
Line Space: Adjusts the spacing between multi-line rows of text.
Margin: Defines the amount of space between the text characters and the border of the Text Box.
Alignment: Defines the alignment of text within the box. The icons represent Left, Center, Right, Top Justified, Middle Justified and Bottom Justified respectively.
