Polygon tool
The Polygon tool creates a shape with any number of sides as a markup. Unlike a polyline markup, polygons are closed shapes and, thus, can be filled. Polygons can also utilize curves and arcs.
- Select the Polygon tool using one of the following methods:
- Go to Tools > Markup >
Polygon. - Select
on the Shapes toolbar. - Press SHIFT+P on the keyboard.
- Select each point of the desired shape. To remove the last point placed, press BACKSPACE.
To close the polygon, do one of the following:
- Select the first point again to close the shape.
- Press Enter twice or press C on the keyboard to automatically close the shape by connecting the last point placed to the first point placed.
- Double-click when placing the last point to automatically close the shape by connecting the last point placed to the first point placed.
Tips:
- Drag to place a rectangular shape. Holding Shift while doing so will force the rectangle into a square.
Delete.
Control points define where line segments meet in a multi-segment markup. Add or remove control points to adjust the shape. See Working with Control Points for more information.
Convert line segments to curves or arcs at control points to match complex shapes. See Working with Curved Markups for more information.
Resize a segment or change its angle: Drag the appropriate yellow handle.
The appearance of the Polygon markup is configurable, including line and fill color, hatch pattern, line width and style, and opacity.
To change the appearance of a Polygon markup, select the markup and select the Properties panel. Go to Window > Panels > Properties to show the Properties panel if it is hidden. Several properties will also be available on the Properties toolbar when the markup is selected.
Color: Sets the line color.
Style: Determines the line pattern.
